Is there a way I can connect a curve to an object? *More to the question*
dennis_bui
Member Posts: 1 EDU
in General
I’m trying to make supports for a small glider, but I don’t know if I can connect a curve to an object that was extruded, so when I change or move the curve, the object changes size. There is an image of what I want to do down below. I don’t know if this is possible or I am probably just missing something really simple. Thanks for the help in advance!
bruce_williams
Member, Developers Posts: 842 EDU
You should use pierce constraintwww.accuratepattern.com0
