Feature pattern incorrect behavior in sheet metal models
frank_ringfrank_ring Member Posts: 44 ✭✭
Hello,
I have noticed that pattern variables as described by Lindsays Early in their
 "Tech Tip: How to Use Variables in Patterns to Vary Features".
only work for sheet metal processing if the sheet metal model is finished first.
 Applying the variables creates a surface and does not behave properly.
Thanks for the attention.
Frank
  • frank_ringfrank_ring Member Posts: 44 ✭✭
    These two pictures show the problem more explicitly.
    Where the sheet metal model is not finished appears the error (Suface)
