Bottle Design : Inserting Drafted Helix onto Drafted Spout (Tapered Helix / Threads)
Lewis_MainaLewis_Maina Member Posts: 12 ✭✭
Hi all, am modeling a bottle that has a draft of 2deg applied onto Spout (see attached image). I need to model threads using a tapered Helix, how can I taper Helix ?...OR how can I taper threads?
  • romeograhamromeograham Member, csevp Posts: 710 PRO
    I agree @S1mon you don't typically need draft there (unless there's some strange conical closure system or something).
    @Lewis_Maina
    Onshape does provide a conical helix if you really need one. You just need to make different selections when you're setting it up:
  • S1monS1mon Member Posts: 3,358 PRO
    There isn’t usually draft on the root surface of the threaded portion of a plastic bottle. That area would be molded with two side pulls.
    @Lewis_Maina
