Easier way to use the flange function for miters
frank_ringfrank_ring Member Posts: 44 ✭✭
In sheet metal processing, unequal angles often come together, as shown here in the example.
Is there a simple way to use the flange function so that the flanges finally have the correct miter?
Here in the picture you can see the result of trying to make both sides with "one" flange.
The individual setting of the miter angles is feasible but also complicated and easily results in discrepancies.
