Returning Booleon Operation Failed issue
thomas_drenththomas_drenth Member Posts: 2 EDU
I am trying to cut off a corner of a cad of 80/20, but i am continuously receiving error "Extrude 2 did not regenerate properly: Boolean operation failed to return a valid part." Is there a way to fix this, am i doing something wrong or am I SOL? Thank you.
Link to document https://cad.onshape.com/documents/765bc44dd31faefadf812def/w/78c762274b9a6039e5077815/e/e698508275046f1ad29d0a32?renderMode=0&uiState=620998e217c1971f9bafc86d
  • wayne_sauderwayne_sauder Member, csevp Posts: 636 PRO
    edited February 2022
    @thomas_drenth
    Your sketch that you are extruding the 80/20 from is not fully constrained. There is an arc in there that is causing the stage behavior. While you can just find and fix the one arc, I would suggest that you fully constrain that sketch. See the help documentation or learning center for more information if needed.
  • lanalana Onshape Employees Posts: 752 image
    The preview shows the extruded body in red - try flipping the extrude direction.
