Tangent mate not working
I've been trying to solve this problem for hours, it was working then decided not to. I'm trying to make a cam/valve relation with the tangent mate. The valves are also on a slider mate and should be going the same direction. The problem is that animating the mate does not work, and it also does not spin like it should. The problem arose after using multiple mates with the same cam and different valves. (8 per times 4 cams). Nothing goes the wrong direction, it just doesn't go. It also gives a few computing/constraint errors.. https://cad.onshape.com/documents/0ff580ae7babfb00179fb540/w/2225ba71d04708a55d72dcba/e/83240121680629316da187a7
