Flat plane over x-y-z (not x-y only)
roland_demmerich
Member Posts: 4 ✭
in Drawings
Hello, everyone,
I currently have a problem with my drawing and haven't been able to find a solution for days.
The problem is: My 3D printer cannot print the part like this.
I would therefore like to have a flat surface on the corner so that I can "lay it flat on the printer".
Unfortunately, I didn't find any help level or something similar - I'm really grateful for every hint.
I hope the picture explains it a little better.
The red area should lie flat on my printer.
But I just don't manage to define an "auxiliary plane" (?) with 45° to then remove it.
- Chamfer adjacent edges then delete the unwanted edge chamfers faces to leave just the corner.
- Loft cut between a sketched line and point.
- If you have a cubic shape (which you do), you can create a parallel plane using 3 points and then use a split/delete or extruded cut.
- Create a plane using line-angle (angle = atan(sqrt(2)) and then use a split/delete or extruded cut.
https://cad.onshape.com/documents/57acdfaae4b005c413ed9b6f/w/3fd585a46d3af1b3ba413c53/e/9b2242f2e0734997f7253e6fCorner Chamfer
