Get lengths/position of points/lines from selected face?
Lauren_Froschauer
Lauren_Froschauer Member Posts: 10 EDU
I am trying to cut down on the number of user inputs for the box joint feature. I remember Kevin mentioning that I could query the length of an edge or the position of a point etc. from a selected face.
Kevin, which command were you referring to? Could you give me some example code using it?
  • kevin_o_toole_1
    edited October 2015
    To get the distance from a point to a plane (i.e. the z-component of the point from the plane's perspective):
    distance is ValueWithUnits = worldToPlane(plane, worldPoint)[2]; (this should probably just be in std)
    To get the length of an edge:
    length is ValueWithUnits = evLength(context, {entities : edgeQuery});
  • Lauren_Froschauer
    Is there a way to evaluate the length of all the edges of a face by just selecting a face?
    Is there a way to return the coordinates of the two vertices that define an edge by selecting the face that the edge belongs to?
  • ilya_baran
    ilya_baran Onshape Employees, Developers, HDM Posts: 1,279 image
    For getting the perimiter of a face, you can pass  qEdgeAdjacent(face, EntityType.EDGE) to evLength. To get the vertices of an edge, query for them using qVertexAdjacent(edge, EntityType.VERTEX) and use evVertexPoint using either the evaluated vertex query or using qNthElement.
