how can i take the thickness value from the sheet metal
PTY
PTY Member Posts: 1 ✭
I've made a copy of "CalculateBounds.fs script" and I've got a script that sets the length and width, but I can't figure out how to get the thickness out of the sheet metal.
I added function calculateFlatSMBounds to the end of the following code which sets the description field to sheet metal dimensions.
function calculateFlatSMBounds(context is Context, id is Id, definition is map)
    const flatFace = definition.face;
    const flatFaces = qTangentConnectedFaces(flatFace);
    // We use evPlane here because it is what newSketch uses
    const flatFacePlane = evPlane(context, {
                "face" : flatFace
    const points = getBoxPoints(context, flatFaces, [], flatFacePlane, definition.edgeSamples);
    var boundingBox;
    if (definition.calculateSmallest)
        boundingBox = calculateMinBox(context, flatFaces, [], flatFacePlane, definition.edgeSamples);
    else
        var boxXDirection;
        if (definition.defaultCSys)
            boxXDirection = X_DIRECTION;
        else
            if (size(evaluateQuery(context, definition.alignEdge)) != 2)
                throw regenError("Please select two points to align the bounds", ["alignEdge"]);
            else
                const boxXPoints = qUnion([qSheetMetalFlatFilter(definition.alignEdge, SMFlatType.YES), qCorrespondingInFlat(definition.alignEdge)]);
                boxXDirection = evVertexPoint(context, {
                                "vertex" : qNthElement(boxXPoints, 0)
                            }) - evVertexPoint(context, {
                                "vertex" : qNthElement(boxXPoints, 1)
        const angle = atan2(boxXDirection[1], boxXDirection[0]) % (PI / 2 * radian);
        boundingBox = getBox2D(points, angle);
    const box3dCSys = coordSystem(WORLD_ORIGIN, vector(cos(boundingBox.angle), sin(boundingBox.angle), 0), Z_DIRECTION);
    const box3d = evBox3d(context, {
                "topology" : flatFaces,
                "tight" : true,
                "cSys" : box3dCSys
    const boxPoints = [
            box3d.minCorner,
            vector(box3d.minCorner[0], box3d.maxCorner[1], 0 * meter),
            box3d.maxCorner,
            vector(box3d.maxCorner[0], box3d.minCorner[1], 0 * meter)
    var sketchBoxPoints = mapArray(boxPoints, function(point)
        return worldToPlane(flatFacePlane, toWorld(box3dCSys, point));
    sketchBoxPoints = append(sketchBoxPoints, sketchBoxPoints[0]);
    const sketch = newSketch(context, id + "sketch", {
                "sketchPlane" : flatFace
    skPolyline(sketch, "polyline", {
                "points" : sketchBoxPoints,
                "construction" : true
    skSolve(sketch);
    if (definition.featureResult == BoundsFeatureResult.PRINT)
        // Print the result to the FS Console
        const unitInfo = getUnitAndUnitString(definition.unitOutput);
        const extents = getExtents(boundingBox, 0, unitInfo.lengthUnit);
        const length = extents.width;
        const width = extents.height;
        //My code, which sets the description field for the sheet metal part dimensions
        setProperty(context, {
                "entities" : definition.bodies,
                "propertyType" : PropertyType.DESCRIPTION,
                "value" : "Plate PL? x "~ length ~ " x " ~ width
        setErrorEntities(context, id, {
                    "entities" : qCreatedBy(id + "sketch", EntityType.EDGE)
        opDeleteBodies(context, id + "deleteSketch", {
                    "entities" : qCreatedBy(id + "sketch")
