Vex chains and sprockets
conner_bradferdconner_bradferd Member Posts: 1 EDU
how do i use create movement between the VEX chains and sprockets. I need to use chains for the vex and onshape composition, so I cant really just pretends it works. any help would be helpful.
  • DrewB_PTCDrewB_PTC Member Posts: 4 PRO
    Hi Conner,
    You can use a gear relation to link the rotation of the sprockets together, but there’s no way to make the chain move - it’s a solid singular part. The chain was made this way so that it would be easy to add detail/show where the chain path would go. Having the chain in your model and linking the rotation of the sprockets together will earn you full points, so no worries!
