Roundng of edges on complex surfaces
alberto_ferraronialberto_ferraroni Member Posts: 6
Dear Onshape Community,
I need to round some edges on a surface made by different splines. The fillet command seems not to work in this specific case. Does anyone has an idea how I could do? My idea is to round this surface (wing tip):
Here is the link to the part Studio:
https://cad.onshape.com/documents/41f5dbd616e27d35acc7eb34/w/7a352171e6e4446fdb6e5c25/e/b81bc5c07da71252439f65e4
Thank you all for your support
Alberto
  • wayne_sauderwayne_sauder Member, csevp Posts: 651 PRO
    @alberto_ferraroni
      If you are just trying to round off the sharp edges then try the fillet tool, uncheck the box for tangent propagation and reduce your radius below 1 mm. Then start playing with edge selection until you get a decent result.
      If you want a full round on the end of your wing, I think you will need to do that with a loft using some guides.
  • alberto_ferraronialberto_ferraroni Member Posts: 6
    Thank you for your answer. I guess that the fillet function will not work but I will try again. If it does not work I will try as you suggest with a loft (I have still to figure out how exactly).
  • nicholas_radzykewycznicholas_radzykewycz Member Posts: 30 PRO
    The filet command fails whenever it gets stuck in a narrow area between two adjoining edges like the tips of your wing. I played around with it a bit and got it to work:
    Link to updated model:
    Alternatively if you don't like it messing with the front edge I would draw out the rounding geometry you want and then perform a sweep remove to clean up the edge the way you want.
    Great thank you all for your suggestions, I will make some tries but at least I know that with the fillet function I can obtain something.
