manipul. of the view shall start from the current persp. instead fro. assambly design center sheet?
heiko_kuenzel
Member Posts: 2 ✭
I‘d like to turn a model in its all directions in the assambly design current view intead from the center of the sheet.
Sometimes
it is tricky to find a suitable perspective to position and build several parts
in the assambly design. Often you must set a highest zoomfactor. if you then
must turn the model, its swings out of the current view.
It is possible to set the perspective (rotate) manipulation actions of the current view ( for examle: current screen center) instead of the assambly design center sheet ??
The theoritical Way, you defined specific named views with the tricky perspectives before you started the manipulations of the assambly is not possible, because you lose the specific Feature Context if you try to switch the other named view - I think its a bug not a feature :-) !!
