Copying instances between Assemblies without versionIDs
I need to copy a large number of parts from other assemblies into a target assembly. The instances in the source document do not have specified version numbers.
I have been trying to use the function "POST/assemblies/d/{did}/w/{wid}/e/{eid}/instances"
It seems that I cannot use microversions to link to instances, as it returns bad request (thought there is a microversion field in the request).
Is there some way to get these parts into a target assembly, whether it is by copying them or linking them, using the API?
