Variable Extrude
I am trying the vary which direction I do an extrude based on where there is material. Essentially, this feature will take a point and make a specific hole pattern and extrude them, but if the point is on the opposite side of an object the feature does not work since there is nothing to be subtracted. I need to somehow be able to vary which direction I extrude based on where the point I select is in relation to the object I want extruded through. Here is my code- https://cad.onshape.com/documents/dd9b41942bbf9f447e9d9d6d/w/2b64a0a98ab7927062949adf/e/d176417788ab53093aeccb69
  • MichaelPascoe
    MichaelPascoe Posts: 2,943 PRO
    edited May 2022
    Hi @jack_white396, welcome to FeatureScript!
    Try something like this:
    This will measure the z distance of the point with respect to the plane. If the point is in the opposite direction of the plane, the distance will be a negative value.
    const distance = worldToPlane3D(planey, point[2]);
     A vector is an array, if you ever need the other values of the vector:
    const x = point[0];
    const y = point[1];
    const z = point[2];
    RENDERCAD
  • jack_white396
    jack_white396 Posts: 7 EDU
    @MichaelPascoe thanks for that advice but what if my plane and point is not in the z direction? As if how do I tell whether I need to use the x, y, or z distances?
  • MichaelPascoe
    I usually measure normal to the plane I'm using, z. This is the local z of the plane, not the global Z of the studio. Can you describe your goal a little more? You may need more inputs, something that you can extract a plane from.
    RENDERCAD
  • jack_white396
    @MichaelPascoe In this example, the point right in the middle of the circle is the point I want. however, the distance between this point and the face of the sphere is along the x axis, not the z. How do I get it to measure the correct way no matter which way the body is oriented?
  • MichaelPascoe
    edited May 2022
    If the cylinder will always be in the part studio, you can have the input be a cylindrical face. One click, I will show you if that is what you want, but I'm still a little confused. What is the feature expected to do? Is there always only a cylinder, or will there be other shapes and conditions?
    RENDERCAD
  • jack_white396
    The cylinder is just an object to test on. I am a member of an frc robotics team, and we often have to design parts to hold bearings in them. The idea of this feature is that the user can select a center point and then the bearing hole and three holes around it for rivets to hold the bearing in would automatically be made in the part.
  • MichaelPascoe
    edited May 2022
    @jack_white396
    Try using an implicit mate connector. If you need to measure the distance instead of a manual entry, you can use the above technique that I mentioned and measure from the startPlane.
    Code:
    FeatureScript 1746;
    import(path : "onshape/std/geometry.fs", version : "1746.0");
    annotation { "Feature Type Name" : "Bearing mount" }
    export const bearingMount = defineFeature(function(context is Context, id is Id, definition is map)
        precondition
           annotation { "Name" : "Start location", "Filter" : BodyType.MATE_CONNECTOR || BodyType.MATE_CONNECTOR, "MaxNumberOfPicks" : 1 }
           definition.mate is Query;
           annotation { "Name" : "Distance" }
           isLength(definition.distance, LENGTH_BOUNDS);
        const startCsys = evMateConnector(context, {
                "mateConnector" : definition.mate
        const startPlane = plane(startCsys);
        const point = startPlane.origin;
        const cent = worldToPlane(startPlane, point);
        const addition1 = vector(0, .690625) * inch;
        const addition2 = vector(((0.690625/2)*sqrt(3)), (-1*(0.690625/2))) * inch;
        const addition3 = vector((-1*((0.690625/2)*sqrt(3))), (-1*(0.690625/2))) * inch;
        const cent2 = (cent+addition1);
        const cent3 = (cent+addition2);
        const cent4 = (cent+addition3);
        const sketch1 = newSketchOnPlane(context, id + "sketch1", {
                "sketchPlane" : startPlane
        skCircle(sketch1, "circle1", {
                "center" : cent,
                "radius" : (1.125/2) * inch
        skCircle(sketch1, "circle2", {
                "center" : cent2,
                "radius" : (5/64) * inch
            skCircle(sketch1, "circle3", {
                "center" : cent3,
            skCircle(sketch1, "circle4", {
                "center" : cent4,
        skSolve(sketch1);
        extrude(context, id + "extrude1", {
                "entities" : qSketchRegion(id + "sketch1"),
                "endBound" : BoundingType.BLIND,
                "depth" : definition.distance,
                "oppositeDirection" : true,
                "operationType" : NewBodyOperationType.REMOVE,
                "booleanScope" : qAllNonMeshSolidBodies(),
        // opExtrude(context, id + "extrude1", {
        //         "entities" : qSketchRegion(id + "sketch1"),
        //         "direction" : -planey.normal,
        //         "endBound" : BoundingType.THROUGH_ALL,
    https://cad.onshape.com/documents/321704cdfedd9bd658ec2def/w/7ed9842c4e5b566356122040/e/29a0ec328e10902c13fd7099?renderMode=0&uiState=62750ae856487c0b606403ca
    RENDERCAD
