Change appearance for all parts
shawn_crockershawn_crocker Member, OS Professional Posts: 924 PRO
I'm am really struggling to find onshape rendering useful for what I am used to doing.  A very usual things that happens for me all the time is, I have applied an appearance to 20+ different parts.  I have decided I need to change a parameter in the appearance.  Do I really have to copy and paste onto all the parts again?  Is there no way to change the appearance and have it update everything that is using the appearance?
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,496 PRO
    Yes, you just have to select the appearance in the "scene appearance" list (rather than selecting a part that has that appearance) and any change you make will apply across everything that uses that appearance.
    That said you have to make sure you applied that same appearance (rather than a new "instance" of it, which I think copy/paste does) to all the parts that are going to share it, i.e. use the appearance from the "scene appearances" list rather than from the main list. I hope that makes sense?
    It helps to rename the appearance after you add it for the first time, then you can keep applying it to other bits and find it again when you need to edit.
    Render studio can do a lot but the interface is seriously clunky! At least it looks like you can now select all the parts that use a specific appearance (if you need to replace it)
  • shawn_crockershawn_crocker Member, OS Professional Posts: 924 PRO
    @eric_pesty
    Wow!  All this time and that never click in with me!  Thanks so much.  While I have you, Immediately I'm not seeing a way, but can one of the colour appearances that came in with a model be converted into a library appearance?  Effectively applying an appearance to everything of the same colour?
    @shawn_crocker
    That I'm not sure...
    I've just been poking around mostly in the dark but this whole appearance stuff isn't exactly intuitive... There are probably people out there that actually know what they are doing that might chime in!
    @eric_pesty
    Yes.  The appearances feel awkward but potentially powerful.  The layout is just so different from anything else I have used (visualize, keyshot)
  • jeff_mcafferjeff_mcaffer Member Posts: 94 ✭✭✭
    <a bit late to the party…>
    @eric_pesty (or anyone else) can you point to the "scene appearance" list? I have an "appearance panel" that pops out from the righthand side in a part studio. I see face and part appearances there and while face appearances have been assigned to multiple faces, there does not seem to be a way to do the same for parts. I, unfortunately, have dozens of part appearance entries there but really only about 4 that are actually different.
    @jeff_mcaffer This is what the appearance scene library is. I used to be in a different place when this thread was created. I usually select a part from the assembly tree and then apply an appearance from the standard library. Then that appearance will be transferred into the appearances folder like in the picture. From there, I apply the appearance from the folder to all the other parts I want it on so that they are all linked to the same appearance. Changing that appearances settings affects all the parts I applied it to.
