Named Mate Connectors
lemon1324
lemon1324 Member, Developers Posts: 230 EDU
When manually creating a mate connector, renaming the mate connector feature (e.g. to "First") will result in that name appearing in the mate query box in an assembly (e.g. "First of Part").
Is it possible to achieve the same functionality for mate connectors placed using a FeatureScript that places many mate connectors at once? Neither mateConnector() nor opMateConnector() appear to take a name parameter. Is it possible to set an attribute, or is this functionality in Assemblies implemented outside the scope of what FeatureScript can access?
Arul Suresh
  • Alex_Kempen
    Alex_Kempen Member Posts: 260 EDU
    If manually renaming a mate connector causes the assembly to update, then renaming mate connectors using setPropery with PropertyType.NAME and value equal to your name should do the trick. Be warned, however, that creating multiple mate connectors per feature can be pretty reliable from a robustness perspective; setExternalDisambiguation (and, by extension, forEachEntity) don't work for mate connectors which have been used in an assembly, resulting in behavior like reordering or removing queries breaking all uses of mate connectors in assemblies for that feature.
    FRC Design Mentor - Team 10553 Orange Overdrive
  • kevin_o_toole_1
    Unfortunately mate connectors are currently named in assemblies via their *feature* name, which is not something which exists or is settable in FeatureScript for mate connectors created inside non-mate-connector features.
    You can file an improvement request to add this capability!
  • Jonathan_Hutchinson
    Jonathan_Hutchinson Member Posts: 162 PRO
    I don't quite get this - is there a workaround to be able to name the opMateConnector result from a sting input parameter?
