API Sketch Geometry ID
Lucas_Crupi
Member Posts: 5 EDU
When calling the /partsudios/d/{did}/{wvm}/{wvmid}/e/{eid}/features from the REST API, there are some geometry references in the form of three characters, eg. "geometryIds": ["JMF"]
I have been able to find the ID of edges using /partsudios/d/{did}/{wvm}/{wvmid}/e/{eid}/bodydetails however, when the referenced geometry is an entity within a sketch such as a line, I cannot seem to find the appropriate API call.
Any help or resources are greatly appreciated.
The documentation has the resolution, thought it's a bit weird:
Feature List API | Onshape Developer Documentation (onshape-public.github.io)
We ask Onshape to run a featurescript query, get the geometry ID as a result, and that there is your geometryId.
Creating knowledge-driven design automation software, for molds, etc.
www.virtualmold.com-1
I believe "entityId" is what you need. See fragment below."entities" : [ {"features" : [ {"type" : 151,"typeName" : "BTMSketch","message" : {"type" : 4,"typeName" : "BTMSketchCurve","message" : {"geometry" : {"type" : 115,"typeName" : "BTCurveGeometryCircle","message" : {"radius" : 0.05423578839196134,"xCenter" : -0.03895397484302521,"yCenter" : -0.03339579701423645,"xDir" : 1.0,"yDir" : 0.0,"clockwise" : false}},"centerId" : "pUzfMw2i2Kly.center","internalIds" : [ ],"isConstruction" : false,"parameters" : [ ],"isFromSplineHandle" : false,"entityId" : "pUzfMw2i2Kly","namespace" : "","hasUserCode" : false,"nodeId" : "M3H5t/In4rdlnyQ+z"}}Creating knowledge-driven design automation software, for molds, etc.
www.virtualmold.com0 -
I see the problem here: Extrude features reference geometry by geometryIds, and while we can get these ids for bodies, there's no id presented for sketch elements. So here's a feature definition:{"type" : 134,"typeName" : "BTMFeature","message" : {"featureType" : "extrude","featureId" : "FukfxxLNUGr2Ytg_0","name" : "Extrude 1","parameters" : [ {...
{"type" : 148,"typeName" : "BTMParameterQueryList","message" : {"queries" : [ {"type" : 138,"typeName" : "BTMIndividualQuery","message" : {"geometryIds" : [ "JGC" ],"hasUserCode" : false,"nodeId" : "FhjpxqVvrJ9zlPM"}
and the arc (or face?) JGC is defined in the program by sketch entity "pUzfMw2i2Kly", but there's nowhere in the API to identify this link.
But if I construct an extrude using a body face as reference, that reference can be found in the bodydetails call.Creating knowledge-driven design automation software, for molds, etc.
www.virtualmold.com-1 -
I have tried this method, and it doesn't seem to work. I was able to get the geometryID of a "part of a sketch", but can't get the geometry of the only edge in that sketch. For context, the sketch I am using has featureID:Fd5TnWYq9UpUQe5_0, only consists of a single line, and is named "Revolute Line".alan_baljeu said:The documentation has the resolution, thought it's a bit weird:
The script that returned the "part of the sketch":
"script":"function(context is Context, queries){return transientQueriesToStrings(evaluateQuery(context, qCreatedBy(makeId('Fd5TnWYq9UpUQe5_0'), EntityType.BODY)));}"
I know this as I tried to use the returned geometryID as a revolute axis:
Then I tried specifying, GeometryType.LINE, and got an empty return value, the script:
"script":"function(context is Context, queries){return transientQueriesToStrings(evaluateQuery(context, qGeometry(qCreatedBy(makeId('Fd5TnWYq9UpUQe5_0'), EntityType.BODY),GeometryType.LINE)));}"
Which returned:{"console" : "","notices" : [ ],"result" : {"type" : 1499,"typeName" : "BTFSValueArray","message" : {"value" : [ ],"typeTag" : ""}},"serializationVersion" : "1.1.23","sourceMicroversion" : "183175352bf8cf2f4fb64556","rejectMicroversionSkew" : false,"microversionSkew" : false,"libraryVersion" : 1803}0
