Trying to add dxf to part
steven_henery
steven_henery Member Posts: 2 ✭
I'm trying to add a dxf of a logo I converted from PNG.
I would like to add it to the side of my part.
My part is a box in 2 parts.
Struggling to get it on the side of my part. Any help greatly appreciated.
  • steve_shubin
    steve_shubin Member Posts: 1,118 ✭✭✭✭
    @steven_henery
    Well to start with — that looks like a bitmap or a raster file that was evidently inside of your DXF
    Because when you bring in dxf’s that are vector, they won’t have the varying line weights — at least not that I remember seeing
    So you may be able to show this graphic file on a plane. But you’re going to have to trace over it with the line tool, the spline or arc tools, the offset and the fill tools, and extrude, because you won’t be able to make this image a part of your object as some apps do with decals
    I’m a hobbyist myself. I do not have the pro version. But I believe I read that you can have decals that can be applied to the side of parts if you have the pro version of Onshape
    But if you’re a hobbyist with the free app like myself, then you’re going to have to trace over it with Onshape’s sketch tools In order to make it part of your object
  • steve_shubin
    edited June 2022
    @steven_henery
    Another option is to use a program that will convert raster or bitmap images into a vector file. Just make sure you have that vector file in a format that you could import into Onshape
    Other folk within this forum could probably tell you what programs to use to convert from raster or bitmap to vector
    Years ago I used to use a program called Vector Magic that worked very good. It was made by some guys out of Stanford. And they have an online conversion service to this day.
    But Vector Magic is not free. You have to pay. And I haven’t really looked at the program in a long time so I’m guessing or assuming or thinking they probably have a DXF vector export. But you would have to confirm that
