Change Linetype Drawing
Axel_KollmenterAxel_Kollmenter Member, pcbaevp Posts: 431 PRO
edited June 2022 in Drawings
How can I change the linetype in drawings?
I want to change some lines of my 3d model to stroke two dot lines. is this possible?
Best regards,
Axel Kollmenter
  • Hans_Ole_LeirvikHans_Ole_Leirvik Member Posts: 82 PRO
    No, it is not possible.
    I also want to show some parts/assemblies with specific linetypes in drawings.
    I have proposed it as an improvement, but don't know when/if it will be implemented....
  • Axel_KollmenterAxel_Kollmenter Member, pcbaevp Posts: 431 PRO
    Ok thanks for your answer. Could you post the link to your IR?
    Best regards,
    Axel Kollmenter
    IR   ?? what ?
    Improvement Request
    Best regards,
    Axel Kollmenter
    I sent it directly to support and got this answer:
    PeteYodis (Onshape Support)
    Oct 21, 2021, 13:47 UTC
    Hi HL,
    Your support ticket:
    "Whish: Show part with dashed linetype in drawing"
    has been marked as an improvement request. Onshape development will evaluate the request and we will notify you if/when this has been implemented. Thank you for helping us make Onshape awesome!
    Pete Yodis
    PD/UX/Support/Community
    Onshape, Inc.
    Join the Onshape Community
    I just saw in Whats New - this feaure is now implementet.
    I have to try it, but it looks like it works only on drawing entities, it looks like you can only pick single edges, not all edges for a part or assembly.
    Finally <3:D  This is perfect!!
    Best regards,
    Axel Kollmenter
