Missing some Math
dirk_van_der_vaartdirk_van_der_vaart Member Posts: 561 ✭✭✭
I'm trying to recreate a sprocket and the even number's are good but the odd number's i get this
https://cad.onshape.com/documents/d43a03d3af3ccb094b049d2f/w/1a702844958ce632eb4de22c/e/fc7d54b585507390455cb51c
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,252 image
    I think the issue is you have half the teeth that the configuration specifies, because it looks like half the circular pattern is failing...
  • dirk_van_der_vaartdirk_van_der_vaart Member Posts: 561 ✭✭✭
    @ilya_baran
    I have made a mistake in the formula, diameter versus radius
