Configuration on assembly
Sébastien_Couet
Sébastien_Couet Member, csevp Posts: 10 ✭✭
edited June 2022 in Community Support
Hi Guys !
I'm trying to update the configuration table thanks to the API on an assembly.
I have the following assembly, and I use the Unsuppressed options to show / no show some assemblies depending on the selected configuration (TD R, TD S)
From the API GET response, I have this json as result:
<pre><code>{
  "btType": "BTConfigurationResponse-2019",
  "configurationParameters": [
      "btType": "BTMConfigurationParameterEnum-105",
      "enumName": "List_wGrOE4o5bor8KL_conf",
      "namespace": "",
      "defaultValue": "Default",
      "options": [
          "btType": "BTMEnumOption-592",
          "optionName": "150%",
          "option": "Default",
          "nodeId": "MYSH75Z8ArrBpqG3f"
          "optionName": "TD R",
          "option": "TD_R",
          "nodeId": "M5jgFXY/HoDfw3v69"
          "optionName": "TD S",
          "option": "TD_S",
          "nodeId": "MfzHLLzf9NF3CIJMZ"
      "parameterName": "Configuration",
      "parameterId": "List_wGrOE4o5bor8KL",
      "nodeId": "MVngN6PqafMbDAn5Q"
  "currentConfiguration": [],
  "libraryVersion": 1777,
  "serializationVersion": "1.1.23",
  "rejectMicroversionSkew": false,
  "microversionSkew": false,
  "sourceMicroversion": "6569130677273c0c01125335"
Questions:
1/ I have no idea from where the nodeId are coming. Also, if I want to add a new option, how to generate a new nodeId ?
2/ I do not see the "unsuppressed" option there.
3/ How to push a configuration to my top assembly node with the API ?
Thanks in advance for your help !
  • alan_baljeu
    alan_baljeu Member, User Group Leader Posts: 111 ✭✭
    "Unsuppressed" is an option in part instances DS1 and in DS2.  If you queried those objects you would see these parameters defined.  In these parameters you would see the nodeId you are asking about.  To get another nodeId, search about in the model for another configurable parameter.
    To apply a configuration to the top assembly node, I think that would be through currrentConfiguration, but I don't have a more exact answer at the moment.
    [aside: this question should be categorized "App store & Partner apps"]
    Creating knowledge-driven design automation software, for molds, etc.
    www.virtualmold.com
  • alan_baljeu
    www.virtualmold.com
