Can I rotate a reference text in a drawing?
Axel_KollmenterAxel_Kollmenter Member, pcbaevp Posts: 436 PRO
I want the reference text vertical. How can I rotate it?
Best regards,
Axel Kollmenter
  • Axel_KollmenterAxel_Kollmenter Member, pcbaevp Posts: 436 PRO
    Thanks @MichaelPascoe this is my current workaround. But it seems like there is no other way to do this.
    Best regards,
    Axel Kollmenter
  • MichaelPascoeMichaelPascoe Member Posts: 2,808 PRO
    I think this is the best way. Another work around would be to put the words in the part studio as a composite part / surface. But this would take longer. Do you have many text that require this?
    RENDERCAD
    No its just a generell question. usually there a just a few textblocks.
    I also think the workaround you told is currently the best. Maybe we can rotate with arrows in the future.
    Best regards,
    Axel Kollmenter
    You can preform an "Alt copy" by pressing and holding Alt as you drag things around. This could improve the workflow if you are working with lots of these.
    RENDERCAD
    Another question: which program do you use to capture which key ist pressed?
    I need this for internal tutorials. I use OBS to capture my screen but I cant show the keys Im pressing...
    Best regards,
    Axel Kollmenter
    edited June 2022
    I placed it in manually with Camtasia. But one software you can show key entries with is QiPress.
    RENDERCAD
    Awesome thanks! I will check it out
    Best regards,
    Axel Kollmenter
