Some Imported Parts Partially Colored, Edit Appearance No Effect
ben_harkin
Member Posts: 8 EDU
I'm importing some STEP files and have found that some parts are partially another color than that in "Edit Appearance" and that changing edit appearance has no effect on the color. In the features list, "Import" is not red.
The entire part should be green. Document link
@ben_harkin
I don't understand why this is happening for sure, however, as a workaround, you can box select then RMB and apply an appearance to all faces.0 -
It's not a bug, it is working as intended. The faces have assigned colours in the STEP file and Onshape is honouring them, however there is a technical reason (which I can't remember what it is) that prevents us from displaying them in the appearance panel.Senior Director, Technical Services, EMEA0
@ben_harkin
Thanks, that works. However it does seem like a kind of bug.0
If you need to add appearance to import, and you need one color for it, you may add appearance to feature.
It will change color for complete import.
2 -
If the face appearances can't be displayed in the appearance panel, does that mean there's no way to remove them?NeilCooke said:It's not a bug, it is working as intended. The faces have assigned colours in the STEP file and Onshape is honouring them, however there is a technical reason (which I can't remember what it is) that prevents us from displaying them in the appearance panel.0 -
You can override them, but not remove IIRCSenior Director, Technical Services, EMEA0
So I'm having the same issues.I have an imported part that is a sheet metal model. All of the bent edges and edges that aren't part of the flat pattern have a color assigned to those faces when imported using the derived feature.So great, it's working as intended. It's honoring the arbitrary face colors that are in the imported file.There needs to be a way to modify or delete what are effectively face appearances being applied to my model that I have zero control over besides going back to the company that I got the model from and get them to export it again.Sure. I can add my own face appearances, but there's no way to get those to change if I want to use configurations to change my part color.
@Mark_Hooper
Have you tried unchecking the new "import face appearances" checkbox?
Also if you want to configure appearances it's a lot easier to manage using something like the "part color" FS: https://cad.onshape.com/documents/d997b0ffc30f659113b10c00/v/a9e4f209775174dbb9f2b5fa/e/b6db0c9545b9a2df1d7ea546?jumpToIndex=8280
