Getting the geometry of a cross-section
carl_malagodi
carl_malagodi Member Posts: 18 EDU
edited July 2022 in FeatureScript
Hello,
I am attempting to add a configurable part through the instantiator functionality to a part studio in a featurescript. However I am lost in how to access and evaluate the cross section of a part. In this use case I have the user select a part and an intersecting plane, I would like to be able to find the geometry of this parts cross-section(square, rectangular, circular) and some measurements about the cross-section, I've experimented with some intersection and owner style queries but I don't have a good grasp on how to start solving this problem. Is there a good way to go about accessing this information?
Thanks
  • carl_malagodi
    So I ended up getting a decent solution for this, there's another forum post here https://forum.onshape.com/discussion/11020/create-sketch-at-intersection-of-face-with-sketch-plane, that kind of details what should be done here, basically Create a copy, split the copy part using the selected plane, then query for the edges created by the split operation, qSplitBy is also helpful here to avoid getting the duplicates that are unavoidable from querying for edges resulting from the split op. Then I used a isQueryEmpty wrapper for geometry types to get the type of cross section type. As a note once you query for the face that results from the split operation you can get the area directly from that using the build in evaluate functions, that can be then used to back calculate things like radius and side length for very basic cross sections.
  • steve_shubin
    steve_shubin Member Posts: 1,118 ✭✭✭✭
    edited July 2022
    @carl_malagodi
    You said —
    Another way is by INTERSECTION
    No copy
    No split
    No affecting the part
    Take a look at the GIF below
    https://cad.onshape.com/documents/dcf6c8e5ee2ad6d1a39d83f7/w/09c23d4aadeddd7894928bb5/e/206a62e3ccdf372b8209c193
  • EvanReese
    EvanReese Member, Mentor Posts: 3,059 PRO
    edited July 2022
    Sounds like about what I'd have tried, this got me curious though, and it turns out you can also generate this surface using opBoolean with BooleanOperationType.SUBTRACT_COMPLEMENT. Not sure if that's better than what you're doing. Maybe it's faster to regen. Check it out. https://cad.onshape.com/documents/4ab43b0c4446570dbf8df0ad/w/66bac2ceafc2a892bb5fc234/e/ae8cec45f479469a79d6a88e
  • Jacob_Corder
    Jacob_Corder Member Posts: 141 PRO
    opBoolean(context, id  , {
            "operationType" : BooleanOperationType.INTERSECTION,
            "tools" :  bodies,
            "allowSheets" : true,
            "keepTools":true,
            "eraseImprintedEdges" : false
    this returns wire bodies of the intersections of the bodies.
