Gear relation and animation.
Ben12Ben12 Member Posts: 7
Hi community, I have designed a mechanical system on Assembly with multiple "revolute" and "Gear" relation between them, when I try to animate all it works only when I do it "manually" (using the mouse and moving one element) but if I play one of the "revolute" that specific one only play correctly, everything else remain steady ??
Is there any process to do to animate all components at the same time?
Thanks a lot by advance for any help.
Ben
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 943 PRO
    It's working for me.
  • Ben12Ben12 Member Posts: 7
    What a surprise! Thank you for your feedback Matt, I will investigate a little bit about my graphic card.
    Ben
