Resolution on Assembly translation and export from API
in General
Is there a way to provid resolution option to Assembly translation request body?
From glassworx I see that there is no such parameter.
From GUI I can do it but I saw that there is another request in use to translate and export Assembly.
(Same as when you select custom).
The coarse/medium/fine are just presets.
For example, a distance tolerance of 0.00024 is used for coarse, and 6e-05 is used for fine.
We specialize in custom FeatureScripts, and Onshape integrated applications
