Feature script / variable pattern part length
We have a part with a hole pattern. The hole pattern has a 30 mm pitch as shown in the image below.
We would like to lengthen or shorten this part in increments of 30 mm.
The objective is to use this part in an assembly to create a structure and change/select the length when inserted in the assembly.
Any direction would be greatly appreciated.
_anton
Member, Onshape Employees Posts: 501
So something like this? https://cad.onshape.com/documents/e37c14510a6911760d726731/w/45a25ae654107f31aef21498/e/c756ab9365e4ec15d69be296
The part is configured with a hole count and hole spacing.0
