Aligning two different parts on a Drawing
patrick_sheapatrick_shea Member Posts: 63 ✭✭
Is there a simple way to align 2 similar parts on a drawing?  They would be almost the same size, but slightly different details.
Shuswap Pat
  • shawn_crockershawn_crocker Member, OS Professional Posts: 931 PRO
    This is about the best method I have found.  It used to bug me quite a bit when I first came through the worm hole from SolidWorks.  But eventually, I just started finding it not really that necessary and 95% of the time, what I just did here is actually overkill.
  • patrick_sheapatrick_shea Member Posts: 63 ✭✭
    Thanks - That is a good option!
    Pat
  • aditya_goel327aditya_goel327 Member Posts: 1 EDU
    I just used a horizontal line on the point of one view and extended it out under the other view. I just used the line as a visual reference to be sure the two view were basically aligned with each other. Then I deleted the line that is not needed anymore and from there, I just group select both views anytime I want to move them so that they travel together. There maybe better ways now though. I think it is possible to actually group views so that they always travel together. Another way would be to project a view off of the first view, then project another on off of the projected one. This will make all three view stay in line.
  • martin_kopplowmartin_kopplow Member Posts: 1,288 PRO
    edited June 2025
    You could put them both (or more) in one single drawing view (e.g. by means of a dummy assembly) and show the one but hide the other part(s) not needed in the aligned views. They will auto-align like normal projected views.
    Sample File
