Edit a circular pattern on a sketch
paul_bartlettpaul_bartlett Member Posts: 98 ✭✭
Is it possible to go back and  edit a pattern in a sketch. I do not see that option.
  • S1monS1mon Member Posts: 3,888 PRO
    Yes and no. You can go back into the sketch and change the number of instances or spacing dimensions, and you can change the alignment of the axes. See this video and this for some cool tricks.
  • outstandingoutstanding Member Posts: 56 ✭✭✭
    @paul_bartlett In particular, one cannot add elements after the sketch pattern has been applied. There is an Improvement Request here that touches it. 4 votes, currently.
