Anyway to force a scheduled workspace update to happen immediately?
JollyJolly Member Posts: 81 PRO
Often when branching or working with old stuff I have to have a workspace update. It's gotten better but sometimes when I say to do the update 'now' and have it kick me out it still ends up rescheduling the automatic update 15min later. Anyway to go back and reschedule it manually?
  • onilssononilsson Member Posts: 3 PRO
    Hi,
    Anything new on this subject ?
    every time I have to update a branch I make sure to close every instance of onshape and that no one else is on the document, but it still ends up rescheduling for 20 min later every time
    Often its just time lost because I'm blocked until the reschedule happen, unless I risk working on the document and end up not closing it in time
  • edward_panedward_pan Member Posts: 10 ✭✭
    I can't believe that after all these years, this issue persists.
  • Matthew_CurranMatthew_Curran Member, csevp Posts: 24 PRO
    edited September 2025
    https://forum.onshape.com/discussion/28640/improvements-to-onshape-august-29th-2025/p1#:~:text=units%20you%20prefer.-,UPDATE%C2%A0WORKSPACE,-When%20Onshape%20pushes
