creating an aligned section with an angle controll
guy_rogelguy_rogel Member, User Group Leader Posts: 93 PRO
I can't find a way to make an aligned section with a controlled angle. in my drawing there is no correct point to pick in the view,
I need to cut in 5 deg.
Am i missing somthing ?
1.png 12.6K
  • mfalkensteinermfalkensteiner Member, Onshape Employees, csevp Posts: 86
    edited August 2022
    The feature you are looking for is called aligned section view. If there is no reference point to keep the 5 degrees, I recommend to create a sketch in the PartStudio and show it for the cut on the drawing view.
    Principal Technical Services Engineer, EMEAI
  • guy_rogelguy_rogel Member, User Group Leader Posts: 93 PRO
    thanks. but I am making a drawing of assembly , not a part.  it is not possible to mkae sketch in assembly. can I use a sketch I made in a part ?
