Bug during the creation of shaded drawings
otaolafr
Member Posts: 113 EDU
Hello,
when we create a drawing of a complex part, the quality of the drawing is reduced to best performance for achieve a good performance and loads during the time that we are working with the drawing. and before exporting it, we can change the quality to best quality to have a precise drawing of it. Nevertheless, the lines of the drawing, indicating the different edges, are correctly updated but, if we have the shaded view turn it on, the colorized layer does not, which can generate drawings like the following ones:
here we can see how the color layer it has lower nomber of polys in comparation to the vector lines, and leaves some open gaps between the two of them, when there should not be any as the vectors represents the edges of the colorized surfaces.
