mouse issues
Hello everyone. I am having trouble with the mouse for moving/rotating the model on the screen. Sometimes it works perfectly, other times it just does not work. When not working the model simply will not move with the mouse, but it does with the arrow keys. When it is in this unhappy state it seems that if I select a surface or 2 on the model that makes it work. I am using a (new) plain laptop for home use and wireless Logitech mouse-this is fine for performance as my models are really quite simple and small. Any ideas?
Thank you,
Bob
Thank you,
Bob
One thing to check is to try using some different browsers to see if this is the problem. Chrome works well as well as Firefox. I prefer Brave which is chrome based.
I had a similar issue a while back except with a Wacom tablet and 3d space mouse. Turns out the space mouse was interfering with my pen drivers + the browser. You could check to make sure there aren't any other devices interfering. Though this is probably not the case here.
RENDERCAD
rendercad.ai - Photorealistic product rendering.
RENDERCAD
