How to mirror a feature?
I would like to mirror the opSweep and opBoolean function, on the opposite side of a cylinder.
The documentation says, that i need a featureList as an input for the instanceFunction. Could not find out, how i can construct it.
Or is there another way I could achieve this??
        opSweep(context, id + "sweep1", {
                "profiles" : qSketchRegion(id + "sketch1"),
                "path" :  qUnion([qNthElement(edges1, 0), qNthElement(edges2, 0), qNthElement(edges3, 0), qNthElement(edges4, 0)])
        opBoolean(context, id + "boolean3", {
                "tools" : qCreatedBy(id + "sweep1", EntityType.BODY),
                "targets" : qCreatedBy(id + "extrude1", EntityType.BODY),
                "operationType" : BooleanOperationType.SUBTRACTION,
                "keepTools" : false
        opPlane(context, id + "plane1", {
                "plane" : plane(vector(0, 0, eLength-(definition.lPiston/2)) * millimeter, vector(0, 0, eLength-(definition.lPiston/2))*millimeter)
        mirror(context, id + "mirror3", {
        "patternType" : MirrorType.FEATURE,
        "instanceFunction" : {},
        "mirrorPlane" : qCreatedBy(id + "plane1", EntityType.FACE)
        });<br>
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,960 PRO
    edited August 2022 Answer ✓
    Hi @sebastian_rigger837, you could try something similar to this:   Sweep  >  Mirror  >  Boolean
    Comments have been placed in the code for easier understanding of what each component does.
    When using featurescript, you can use the opPattern operation to copy parts in various ways of transform.
    FeatureScript 1821;
    import(path : "onshape/std/geometry.fs", version : "1821.0");
    annotation { "Feature Type Name" : "Sweep Mirror" }
    export const sweepMirror = defineFeature(function(context is Context, id is Id, definition is map)
        precondition
            annotation { "Name" : "Profile to sweep", "Filter" : EntityType.FACE }
            definition.profile is Query;
            annotation { "Name" : "Sweep path", "Filter" : EntityType.EDGE, "MaxNumberOfPicks" : 1 }
            definition.path is Query;
            annotation { "Name" : "Mirror mate", "Filter" : BodyType.MATE_CONNECTOR || BodyType.MATE_CONNECTOR, "MaxNumberOfPicks" : 1 }
            definition.mirrorMate is Query;
            annotation { "Name" : "Targets", "Filter" : EntityType.BODY }
            definition.targets is Query;
            // Sweep profile along path
                        "profiles" : definition.profile,
                        "path" : definition.path
            // Get the swept part
            const sweptPart = qCreatedBy(id + "sweep1", EntityType.BODY);
            // Turn the mate connector into a coord system
            const mirrorCsys = evMateConnector(context, {
                        "mateConnector" : definition.mirrorMate
            // Create a construction plane to mirror accross
            const mirrorPlane = plane(mirrorCsys);
            // Pattern is used to copy and mirror things
            opPattern(context, id + "pattern1", {
                        "entities" : sweptPart,
                        "transforms" : [mirrorAcross(mirrorPlane)], // Transform is placed inside an array []
                        "instanceNames" : ["Copy"] // Names are placed inside an array []
            // Get the mirrored parts
            const mirroredParts = qCreatedBy(id + "pattern1", EntityType.BODY);
            // Debug the parts green
            debug(context, qUnion([sweptPart, mirroredParts]), DebugColor.GREEN);
            // Boolean subtract the parts from the target
            opBoolean(context, id + "boolean1", {
                        "tools" : qUnion([sweptPart, mirroredParts]),
                        "targets" : definition.targets,
    https://cad.onshape.com/documents/343178350105cea556ab3d23/w/990bfe172e0ed3c440868636/e/a7b94e644da0af9ed6cb77ad
  • MichaelPascoe
    FeatureScript 1821;
        precondition
