Combine the positon of a hole with another part
Hi,
I want to combine the position of hole with another part, So I don't have to care about measuring and sketches.
Here is an example of what I mean. It's a linear bearing imported via step and a plate. Of course I need some holes in the plate for mounting. I cant find a solution for hours now, any help would be welcome
Many thanks
Lars
Many thanks
Lars
You could derive the linear bearing into the same part studio in which you are creating the mount plate, then use a constraint to relate the mounting hole positions to the holes in the bearing.
What I did.
now I use the transform function th move the bearing and that damn hole stays where it is ...
Just a small detail to complete your understanding: the feature list is like a historical sequence: anything you add cannot affect anything further up the list.
So you just need to drag the "Transform" up the list so it happens before the creation of the hole.
