New to CAD, need some assistance with a shape
david_gelb
Member Posts: 2 ✭
in Drawings
Hi, I am trying to model a set screw protector and am unsure how to do this. I am creating a piece that fits over a set screw and creates a flat surface to rest against the surface the set screw is clamping onto - basically, to prevent the screw from scratching the surface it is mounting to.
I created the flat surface in OnShape, and then created the cylinder that the screw would sit in, but I am unsure how to give the cylinder thickness. I am not sure I am describing this well, but on the image below, I need to fill the space between the grey and blue cylinders. The set screw would sit inside the inner (blue) cylinder.
If this still isn't making sense, I can try to send other images.
Thank you,
David
Thank you,
David
https://learn.onshape.com/learn/course/introduction-to-part-design/part-studio-interface/introduction-to-parts
