Why does this extrude different ways?
imamac96
Member Posts: 3 ✭✭
I have an extruded sheet metal piece from a sketch that has a linear pattern. I am drawing angle that follows and cannot intersect a slanted line on the other side. When I extrude the sketch, the original sketch entity extrudes one direction while the patterned entities extrude the other way. Reversing the extrusion direction flip-flops the results. I'd like to understand if this is a bug/feature or if there is a way around this if this is intended. Does anyone know?
Thanks,
Connor
Thanks,
Connor
