Document Labels via API
Hi!
I'm trying to assign label to document using API. I've been searching for it on Glassworx documentation with no result.
I found only a way to fetch existing labels from this: https://ftconshape.com/using-the-onshape-client-api-with-go/
Is it possible to create label if not exists and assign it to document?
Łukasz
POST /api/labels
with a body like:
name: your label name,
ownerId: userId
this request returns and object containing a bunch of stuff including an id (labelId)
You can add a document to a label via:
POST /api/labels/{labelId}/uses/documents?documentIds={did}
which i think takes in a body like:
documentIds: [did],
labelId: labelId
And to search for documents under a label you can use the /api/documents/search with the label id set as the owner id
Edit: API endpoint is not public
We specialize in custom FeatureScripts, and Onshape integrated applications
Axel Kollmenter
You could put in an improvement request to make it public.
