Enable rotation of selected components in a sketch while updating constraints accordingly
Being a developer engineer and a maker, many of my projects are being developed as I sketch, sometimes I import copied lines from another sketch, and sometimes I simply realize that the position I chose for a component is better to be in another orientation, allowing to rotate selected components within a sketch while updating its constraints (horizontal, vertical) to the 'new' desired rotating will be huge for me.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,602 PRO
    The "transform" sketch tool overrides constraints to let you rotate you selection.
    Another option is to use a mate connector for you sketch (instead of a plane/face), this way you can rotate the mate connector to change the "horizontal" direction of the sketch to whatever you want.
  • ofer_libermanofer_liberman Member Posts: 16
    Thank you Eric,
    Found it, it seems to do exactly what I was referring to and then some more.
