How to change a surface into a part
jason_chen506jason_chen506 Member Posts: 2
I have been trying to create a hole in my car, but it won't work because it is not a part. Can someone help me? Link to my document: https://cad.onshape.com/documents/9d1577b779f253c97c5e68c1/w/8fa339fbd82b24ae7ca86cb4/e/3259f575b6950c7109f94879
  • GWS50GWS50 Member Posts: 498 PRO
    It looks like your car is modelled using surfaces so you can either 'Thicken' the surfaces using the thicken tool which will turn the surfaces into parts, or you can draw a sketch on the surface i.e. a circle and use the split tool to 'Split' the surface and then delete the hole using the 'Delete Surface' tool
  • matthew_stacymatthew_stacy Member Posts: 489 PRO
    @Jason_Chen, there are two approaches to transform a surface/s into a solid:
    1. "Thicken" the surface (as described by @GWS50 ), or
    2. "Enclose" the surface to create a fully enclosed volume (often followed by applying the "Shell" tool)
    Onshape has tools for both of these workflows.
