Placing line in a sketch to the surface of a curve?
jonathan_wong
Member Posts: 4 ✭
So suppose I a sketch and I make a line in it. How do I place that line at the intersection of that line and a surface?
For example, I want to make the line on the left touch the surface on the left side.
Also, how do I select a hidden line so I can make one of my other lines coincident with it? And how can I select a line from another part?
Try 'Use/Project' tool in sketch. It will allow you to pick up existing elements into your sketch.//rami0
You can use the pierce constraint to attach the end points of the rectangle to the surface edges.
1 -
@ jonathan_wong,Please find the below thread for more information
https://forum.onshape.com/discussion/1931/aligning-features-on-sketches-in-different-planes#latest
