Set Assembly Name from Variable Studios
michael_thunesmichael_thunes Member Posts: 3 EDU
I would like to be able to update all of the part names and assembly names based on a variable housed in my variable studio.  I figured out how to rename parts but have been unable to figure out how to rename the assembly.
Is there a way to rename an assembly based on a variable studio variable?
Example:
Variable name: year = 2022
Assembly name: 2022_assembly
If I change the year variable it will update the assembly name to reflect the new year.
  • chadstoltzfuschadstoltzfus Member, Developers, csevp Posts: 164 PRO
    Currently you can't access variables (of any kind, not just ones in variable studios) in things like the tab/document name. The only way I can thinking of approaching this is using the API, which does have exposed endpoints to look inside variable studios.
    chadstoltzfus@premiercb.com
  • michael_thunesmichael_thunes Member Posts: 3 EDU
    I have found that you can not name the Assembly studio via a variable, are you able to name the assembly (inside the studio) via a variable?
