Depth control for section views
ron_morelandron_moreland Member Posts: 90 ✭✭
edited October 2022 in Drawings
I've seen this topic here and there in the forums. Is there a way to limit the depth of a section view? I'm using Onshape to make some architectural structural views. When I make a section view, the background framing makes a jumble of the section. Limiting the depth would make life easier. I've been able to get what I want by hiding sections of the structure with visibility.
  • GWS50GWS50 Member Posts: 498 PRO
    If you right click on the section view you can edit the section view and in the dialogue box there is an option to control the depth of that view
  • ron_morelandron_moreland Member Posts: 90 ✭✭
    That works! Thanks!
