Lenght of the pipe in the cutlist
juha_hoo
Member Posts: 4 ✭
I'm modeling a pipe with bendings by using sketch, frame-tool and pipe profile. Then I create cutlist. For some reason the lenght of the pipe is wrong in cutlist compared to mesured in the sketch. Can one help me how I could get the right lenght to the cutlist.
I'm wondering why in this example, the cutlist is showing a smaller length then the center sweep path? If the calculation is done on the outer arc of the sweep, shouldn't the cutlist length value be greater than 657mm?
