API: Retrieve Variables - Measurements Are Incorrect
Using /variables/d/{did}/{wv}/{wvid}/e/{eid}/variables endpoint, the values that are returned for a 'measured' variable are incorrect. I'm not sure if it would require a configuration parameter perhaps, but currently in my document it is defaulting to a random value.
Overriding the calculated value with, say, a plain integer returns me the integer fine and it also updates. So it looks to me like like it's a problem with measurements output.
Also set: 'includeValuesAndReferencedVariables' = 'true'
  • _anton_anton Member, Onshape Employees Posts: 528 image
    Yep, this is a bug. This endpoint should accept a configuration. Thanks for finding this, and sorry for the inconvenience.
