Model orientation rotated when exported as gltf
Fil
I made the above model in onshape which I am trying to export as a gltf file so that I can use it in Adobe Aero.
However, when exported as gltf, it rotates the model to a different orientation (windows explorer excreenshot). When I export the assembly as an STL, it stays in the correct orientation.
Any ideas on why it may be rotating that way?
  • S1monS1mon Member Posts: 4,062 PRO
    I assume because Onshape is a Z-up system and some other tools are Y-up.
