Servo Control Arm Push Rod Linkage Assembly Mating
This seems like it should be something that is possible, but I can't work it out
I have a simple pivoting bogie wheels being rotated by a servo through a push rod
Everything is connected, I can rotate the servo horn and te pushrod moves, I can grab the push rod and move it about the servo horn following correctly, I can pivot the front wheel around it's center correctly, but no matter what I ry I can't make that last connection between the pushrod and the wheel bogies,
https://cad.onshape.com/documents/4dc71a6343911d61e19ed1f0/w/6370c16ba2491c37d570ebf0/e/21ccedd5221a9f342eae3737?renderMode=0&uiState=6377114e4780e47070fd091b
Is it possible?
Is it possible?
https://cad.onshape.com/documents/7e3e8c7cb09119281bc5f18d/w/7c888edcded7f862a14cce44/e/4aa37ffedd82f84b7f804f6e
