How do I make imas not see through?
in Drawings
Like the title says, I wanna make the images not transparent
Hi @jose_iglesias014, this would be good to have. I have needed it in the past as well.
Currently, all sketch images are transparent. Here is an improvement request you can vote on:
https://forum.onshape.com/discussion/2718/decals-or-images-as-skins-on-solid-faces-or-surfaces/p1
While you are inside a drawing, you can slide the preview slider left or right to control the drawing transparency. Unfortunately, this is only while you are in the drawing.
Alternately, you can use custom features to get the job done. Here is a quick feature I wrote you can add to your toolbar:
Special thanks to @Konstantin_Sh for teaching me the secret code for getting this to work.
Image (Custom Feature)
Just click the "+" button at the top of the document to add the feature to your toolbar.https://cad.onshape.com/documents/f7a45d78c374497d37c1d2cb/w/04c6c220e40120d79db4c05e/e/161ce64bb947e34f19588b33?renderMode=0&uiState=63777c7568307e0562d00254
