I can't be able to make a Projected Curve on my iron man helment.
kevin_lin238kevin_lin238 Member Posts: 4
I have a problem with my projected curve 11, I can't be able to make it out. It says it was an error. I would like to make a curve on these two line. I hope this would be an honor for your help.
URL: https://cad.onshape.com/documents/2c8235e0be2ab056354943d6/w/fde59e8189ea48884ef168d9/e/a825c66d403ffdfcbab2a0be?renderMode=0&uiState=63821a700297f85885bca9e7
  • MichaelPascoeMichaelPascoe Member Posts: 2,818 PRO
    edited November 2022 Answer ✓
    Hi @kevin_lin238, looks like your off to a great start! When projecting two sketches, make sure the max and min geometry of the sketches line up properly. In this case, the lowest portion of your 2nd sketch was not horizontal with the lowest portion of your projecting sketch. Also, sometimes it is best to break it up into multiple projections. See the gif tutorial below:
    https://cad.onshape.com/documents/a9dc30d40dae74fab90f6b21/w/083508b1b58a0f9f849615d5/e/4073e14e618153d9a701bf3d?renderMode=0&uiState=6383da19730e06060b3eff93
    RENDERCAD
  • S1monS1mon Member Posts: 4,082 PRO
    I also notice that there are a bunch of lines in the side view which are drawn using splines, but they have no or almost no curvature. This will likely add unneeded complexity to the projected curves. I would recommend using straight lines for these instead, unless you think you will be adding some curvature to them later.
    RENDERCAD
  • kevin_lin238kevin_lin238 Member Posts: 4
    Thank you Michael, I am appreciate for your help. I hope you have an wonderful day.
