transfer onshape part to a file
peter_riedelpeter_riedel Member Posts: 2
I want to transfer a part I made in onshape to a friend by mail so he can edit it but what format do I need to export it to so he can edit it later on?
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,590 PRO
    I think it mostly depends what you friend is going to use to edit the file...
    If you friend was using Onshape, you could just "share" the document with them (which would be the easiest way to do it!)
